AE CS3 Having problems with pre ram preview and renders
Josh Mackey
on Apr 14, 2010 at 11:09:33 pm
I'm hoping someone can help... I'm running CS3 and working on a project for the last 3 weeks... Everything has been fine except for a few glitches in the ram preview and render where background layers are not rendering correctly. They will play and then stop, jumping back and forth from 2 frames.
I have checked all of my codec's again today and re rendered my master QT files all at the same frame rate @ animation codec. But it contiues to happen.
When I go back and check my master files they run fine in Quick Time.
Suggestions?
Jeffrey Kaplan
Re: AE CS3 Having problems with pre ram preview and renders
on Apr 15, 2010 at 8:20:40 pm
What codec are you using for the files in your project?
Jeff Kaplan
Point 360 WEST
Animation & VFX Department
http://www.point360west.com
