characters flying off a block of text
toma euvrie
on Apr 11, 2010 at 2:37:13 am
hi all, i am trying to recreate this in After effects:
I guess it has been generated with particle flow in 3ds but i think ae should be able to do it. I thought about using shatter, but i want to repeat this effect with different block of texts and fonts, so it would be very painful to have to redo each time a shatter map. Then i think particular, but i just don't see how to input each character as a particle...and particle playground cannot give a fake 3d perspective per character so it is no good for me (and very very slow plugin).
toma euvrie
Re: characters flying off a block of text
on Apr 11, 2010 at 4:14:25 am
i found the solution, so i reply to myself:
pre-comp the block of text
apply shatter effect to it
use the pre-comp itself as custom map!
then think about de-activating anti-aliasing on the text and on the precomp, to obtain an accurate shatter map. Blur the edges afterwards
© 2018 All Rights Reserved
