Black Drop Frame Issue
Lizzie Turner
on Apr 7, 2010 at 3:13:28 pm
Im having trouble with camera movement causing a black frame.
Heres a screen shot because the I have no idea why its happening
http://img179.imageshack.us/img179/6617/blackframeissue.jpg
As you can see I have 3 keyframes for the camera dolly position. Before adding the third keyframe there is no issue, but after adding it, no matter what value i change i get a black frame between the second and third keyframe.
I dont understand why this is happening as 'bits' and 'pre comp 1' should be visable.
I have have tried taking easy ease away but that just moved the black frame.
If anyone could help it would be great - this is driving me crazy!
Lizzie
Tudor Jelescu
Re: Black Drop Frame Issue
on Apr 7, 2010 at 4:53:41 pm
since you have a 3d comp it may just be that you get a black frame when the camera passes through a plane in 3d space.
