Set Render Engine Setting As Default
joseph wilkins
on Apr 6, 2010 at 5:31:48 pm
So I created a new preset for my preferred render setting, but cannot figure out how to set it as my default, so I dont have to select it from the drop down in the render queue every time I render..
Can anyone help?
Cheers
Walter Soyka
Re: Set Render Engine Setting As Default
on Apr 6, 2010 at 5:36:32 pm
Add an item to the Render Queue, click the triangle next to "Render Settings," and then click "Make template."
From that screen, you can select what the default render settings are for each render type.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Erik Waluska
on Apr 7, 2010 at 12:18:50 am
The shortcut is to just hold down Ctrl (Cmd - mac) as you select the preset from the drop-down menu, which makes that preset the default.
-E
