FCP to AE and back
Michael Worth
FCP to AE and back
on Apr 4, 2010 at 12:43:51 am
Hello,
I have a problem possibly someone may help with. I am working on mostly music video's I am exporting from FCP to AE adding effects and art and then exporting back to FCP. Everything looks great, but when I export from AE to FCP and open and replace the file into the previously editing footage, it is shorter in length.
Currently I am adjust the time of the clip to make it fit back into the edit, but it is very time consuming.
I am matching the settings in FCP and AE with frame rate and HD 1080i
What may I be missing?
Alperen T. Ayhan
Re: FCP to AE and back
on Apr 6, 2010 at 7:45:59 am
Is it posibble? I do not know, but check your composition settings. Or be sure; in timeline you have the same length as it's shown below..
Alperen T. AYHAN
http://www.sinamasal.com
Always cinema...
Michael Worth
on Apr 6, 2010 at 9:13:26 am
Hi Alperen,
Yes those setting are accurate. I thought it may have something to do with the compression or the fps, but they all match up when I read the clip description in the final cut window.
Thank you for the input.
