Importing PDF to After Effects
Ben Muehleisen
on Apr 2, 2010 at 4:39:14 pm
HI!
I am trying to import a 40 page PDF into After Effects so I can manipulate each page separately. AE seems to only want to import the first page of the PDF. I can save the PDF as JPEG using Preview, but I have to select each page and save each page individually.
Is there a way I can:
1. Import my PDF straight into AE with each page as an individual file.
2. Batch save the PDF as JPEGs, so I don't have to do it 40 times.
I have CS4, so I have Illustrator, Photoshop, Bridge and other programs, if one of those would work better for importing.
I am also having trouble when I import the PDF, it imports as vector art, with all the white space turned to alpha.
Any help is wonderful. Thank you.
Under The Line
an affordable solution for all your video needs
http://www.underthelineproductions.com
Todd Kopriva
Re: Importing PDF to After Effects
on Apr 2, 2010 at 7:06:02 pm
After Effects only imports the first page of a PDF file.
But you can use the Document > Split command in Acrobat to split (a copy of) a document into individual pages. Then you can just import the folder full of individual-page PDF documents.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Brian Charles
Re: Importing PDF to After Effects - Alpha Issue
on Apr 3, 2010 at 2:35:34 pm
I routinely get PDF's from clients and have several dozen at a time. TO get rid of the alpha I created an action in Photoshop – adding a layer filled with white below the image then merge down – which I then batch in Photoshop.
