After Effects imports TIFF as footage with fewer frames than source files
Matt Cheah
on Apr 1, 2010 at 6:57:36 am
Hey all,
I've been exporting some footage as TIFF files and I still need to edit a little bit, so I import it all back into After Effects but I've run into a little problem. There's a total of 888 TIFF files, but when I import it back into After Effects, there's only 708 frames, as if it's just been time-remapped that way. Any idea why it's doing this and what I can do to fix it?
Much Appreciated.
anita sancha
Re: After Effects imports TIFF as footage with fewer frames than source files
on Apr 1, 2010 at 7:39:39 am
hi..
I find that whenever I get issues like this one I take it in and out again of quicktime pro.. as same or another sequence or mov or whatever.. but I am no pro and it may still have the same problem, but often it gets it sorted for whatever reason.
Anita
Thanks for all your help
Anita Sancha.
http://www.anitasancha.co.uk
Dave LaRonde
on Apr 1, 2010 at 1:46:06 pm
After Effects defaults to a 30 fps frame rate for image sequences. If you're working in 29.97, that could be a problem. So go to the Interpret Footage settings, check that frame rate, and re-conform it if necessary.
Dave LaRonde
Sr. Promotion Producer
