fliks´s light
juan prado
fliks´s light
on Mar 31, 2010 at 4:25:18 pm
Hello:
Any advise to avoid flick´s light?,plugins,tricks,etc
Thank a lot
Todd Kopriva
Re: fliks´s light
on Apr 1, 2010 at 1:04:50 am
I don't understand the question.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
juan prado
Re: fliks´s light
on Apr 1, 2010 at 6:21:49 am
Sorry about my English.It´s when you have shooted with a specific lights.It´s appear like a constant flicker light in the sequence.
Thanks again.
Todd Kopriva
Re: fliks´s light
on Apr 1, 2010 at 1:23:23 pm
If you need to stabilize the color and brightness in a shot because of flickering lights, then you can start with the Color Stabilizer effect.
Dave LaRonde
Re: fliks´s light
on Apr 1, 2010 at 1:43:56 pm
It is usually wisest to simply re-shoot if it is at all possible. Todd's recommendation of the Color Stabilizer effect will work with different degrees of success.
For example, if the flickering lights affect everything you see in the shot, you could have good success. If the flickering is worst in only certain areas of the shot, you may need to duplicate the layer and isolate the bad parts with a mask, and then apply the effect.
Dave LaRonde
Sr. Promotion Producer
