Data from position
Kasper Nyman
Data from position
on Mar 31, 2010 at 2:18:14 pm
Hello
I want to pull out some data from my position of a object, Null. Exporting it to somekind of code-file, so can use it in XML or just numbers, to use for Placement of extern object.
Any idea?
Nyman
Nyman
Bartek Skorupa
Re: Data from position
on Mar 31, 2010 at 3:56:47 pm
I don't know if it helps, but you can simply select the position of the null, copy it (Ctl-C), open any text editor and paste it.
Bartek Skorupa
Warszawa, Poland
Todd Kopriva
on Apr 1, 2010 at 1:10:28 am
Here is some more information about what Bartek is talking about.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
