Camera Motion Not Producing Motion Blur
Matt Reyer
on Mar 24, 2010 at 3:35:15 am
I have a composition with 3D objects and a camera. Motion blur is turned on for everything, and in the composition switch. When I move any objects in X, Y, or Z space, motion blur is created correctly. However, when I move the camera (it is very quickly, so motion blur should be created), no motion blur is created. How do I make it have motion blur just like everything else?
Thanks in advance!
Matt
cowcowcowcowcow
Darby Edelen
Re: Camera Motion Not Producing Motion Blur
on Mar 25, 2010 at 3:43:57 am
I'm at a loss.
Something is obviously wrong, but I can't imagine what it might be. So I'm going to blame the usual culprit: disable OpenGL if you have it enabled.
You're still not seeing motion blur from camera motion when you render? Can you post a render so we can see what the problem looks like? Can you post some screenshots of your timeline?
Darby Edelen
Matt Reyer
on Mar 25, 2010 at 10:02:06 pm
Ah! You're smart! Turning off OpenGL solved it.
I assume OpenGL causes problems like this often, or is it just with motion blur?
cowcowcowcowcow
Darby Edelen
on Mar 25, 2010 at 10:41:53 pm
The OpenGL renderer does not support all of the features that the After Effects software renderer does.
Darby Edelen
