Large Composition Crashing - Recommended Settings
Harrison Lee
on Mar 23, 2010 at 10:53:11 pm
I'm trying to render out a jpeg sequence of a 4508 x 290 composition. There are a lot of layers and masks/roto, lens flares. I haven't been able to get through a render without crashing. Anyone have any suggestions for memory/cache settings? I'm already using the secret pref to purge after each frame. Just trying to see if I'm missing anything, before I go in and start pre-rendering elements to get through this render.
AE CS4
Mac OSX - 10.6
2x2.93 GFz Quad-Core Intel Xeon
16 GB 1066 MHz DDR3
Dave LaRonde
Re: Large Composition Crashing - Recommended Settings
on Mar 23, 2010 at 11:08:10 pm
If you haven't done so already, turn off Open GL for rendering and get the free AE 9.0.2 upgrade.
Dave LaRonde
Sr. Promotion Producer
Harrison Lee
on Mar 23, 2010 at 11:25:38 pm
Thanks, Dave. Going to install the update and see if that helps.
Walter Soyka
on Mar 24, 2010 at 2:20:49 am
If you're using multiprocessing with 8 cores and 16 GB of RAM, you might consider limiting the number of CPUs available to After Effects (see "CPUs to leave for other applications" on this page). This will help you avoid starving your processors of memory.
Also, I usually render to image sequences; if the render fails for any reason, you can re-render the image sequence with the "Skip existing frames" option to pick up where you left off.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Harrison Lee
on Mar 24, 2010 at 6:36:12 am
Installed the update, turned off open gl, and reduced cpu's to AE. Left the render going overnight and will post best results/settings. Should I have enable layer cache and multiprocessing switched on? I do now.
Harrison Lee
on Mar 29, 2010 at 8:34:40 pm
So I implemented all of the suggestions from Dave and Walter, and I also tried rendering as a TIFF sequence as opposed to JPEG, based on a suggestion from Mylenium over at the Adobe forums (http://forums.adobe.com/message/2697994#2697994). Render still crashed after about 40 frames. I've bitten the bullet and started pre-rendering out my pre-comps in hopes that AE can handle it better now. Thanks for all the suggestions.
Dave LaRonde
on Mar 29, 2010 at 9:28:41 pm
Thanks for checking back. Few people do.
Dave LaRonde
