Adjusting duration makes layer invisible?
Kaela Waldstein
on Mar 21, 2010 at 9:10:03 pm
I am using the Videocopilot "Energy" effect in one of my projects. It uses a precomposed layer called "Twister" which is comprised of three layers: Camera, Core, and Twister. I must have messed up somewhere, because the Camera and Core layers are fifteen seconds in duration, while the Twister layer is only a fraction of a second long. I want to adjust the whole precomposed layer to be six seconds long, like the rest of the comps in my project. But when I do that, the effect is no longer visible in my main project window -- the layer is there along with the other comps but there is no layer bar for it.
Does this make any sense? I am quite stumped.
Thank you!
Michael Szalapski
Re: Adjusting duration makes layer invisible?
on Mar 22, 2010 at 1:18:53 pm
How did you adjust the length? I'm guessing when you adjusted it your layer just moved in time. Select your layer and press alt+home (or option+home) See if that brings it back.
Or, since it's really short, it may just be too skinny for you to see. Go to the end of your comp and press alt+] (or option+]
- The Great Szalam
