Interlacing and Synching footage
Albert Major
on Mar 20, 2010 at 5:38:36 pm
I am a new user and I am working on a file previously exported from Premiere at 29.97 with lower fields first but when I import into After effects, it is interpreted as 29.969. I've done the effects necessary but when I rendered the file it was no longer in sync with the original track and didn't fit in it's slot in after effects (either a bit longer or shorter). Is there a way to fix this?
thanks
Todd Kopriva
Re: Interlacing and Synching footage
on Mar 20, 2010 at 10:58:06 pm
If the problem is jsut that the footage item's frame rate is being interpereted incorrectly, then you can change that yourself. See this page for instructions.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
