multi sequence re-render
Pino Sortino
on Mar 13, 2010 at 1:33:41 pm
hello all
I've just finished to render a 80 frame targa sequence. basically there are some problems on the last 20 frames and i'd like to re-render just them. what i have to do to avoid afx to overwrite the first 20 frames and render just the last 20? I've tried to set the in and out point from 60 to 80, but the targa render names file start again from the beginning 00001 and not 00060...
thanks in advance
Todd Kopriva
Re: multi sequence re-render
on Mar 13, 2010 at 4:29:56 pm
You can delete the exported files that you want to redo, duplicate the render item in the Render Queue panel, and set it to skip existing frames. See "Render settings".
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
