Render Problems
Faraz Mozafarian
Render Problems
on Mar 12, 2010 at 8:26:20 pm
Hello,
I ham having problems with my output. I have a comp with some glows and various effects. However, when I export and import into final cut some of the glows are now gone. and various layers are getting cut off like adjustment layers and things. I have tried exporting with the ANIMATION CODEC and the APPLE PRO RES 4444. Should I be using another format? am I missing some settings?
Please help as this is for my job and I need to get this right.
Thank You!
Faraz Mozafarian
Re: Render Problems
on Mar 12, 2010 at 8:39:24 pm
Ok,
So it works when I export to Apple Pro Res 422(HQ) anyone know why that is?
Bob Root
Re: Render Problems
on Mar 12, 2010 at 8:40:27 pm
Check your render settings to make sure that your effects aren't set to "off".
Bob
Bob Root
Re: Render Problems
on Mar 12, 2010 at 8:42:38 pm
Oops.. my bad.
Didn't see that this is an export. Can you render your files and take them into FCP?
Faraz Mozafarian
Re: Render Problems
on Mar 12, 2010 at 8:45:18 pm
Yes. I have tried rendering with ANIMATION, PRO RES 4444 and PRO RES 422. The only one that works in PRO RES 422.
