Distort effect
William Saviola
Distort effect
on Mar 9, 2010 at 4:36:18 pm
Hello
I am trying to find an effect i it has to be in distort somewhere, where i can create the oppersite effect f the bulge effect
It can be done using CC cylinder however this is a long and annoying process and there must be a quicker method
If i could go in to minus in the bulge effect this would be the answer however you cant go in to minus in the bulge effect
Here is a example of what i want to do
From my example you can see a the solid in the middle with this effect and it also has the small symbols tht are curving around to
Thank you
Dave LaRonde
Re: Distort effect
on Mar 9, 2010 at 4:48:49 pm
[William Saviola] "I am trying to find an effect i it has to be in distort somewhere, where i can create the oppersite effect f the bulge effect "
How about if you simply set the Bulge effect's height to a negative value? Unless I misread your intent, that sure sounds like the "oppersite" of Bulge to me!
Dave LaRonde
Sr. Promotion Producer
William Saviola
Re: Distort effect
on Mar 9, 2010 at 5:14:50 pm
with the bulge effect you cant enter a negative value
I have used the warp effect with the style set t bulge how ever even with the layer collapsed i am still getting some pixelated edges
Would you know how to fix this with out blurring it ???
Dave LaRonde
Re: Distort effect
on Mar 9, 2010 at 5:25:22 pm
[William Saviola] "...with the bulge effect you cant enter a negative value "
The following is from Adobe's Online Help about the Bulge Effect, which can be found here:
http://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103a9d...
"Bulge Height The apparent depth of the bulge. Positive values push the bulge toward the viewer. Negative values pull the bulge away from the viewer."
Dave LaRonde
William Saviola
Re: Distort effect
on Mar 10, 2010 at 3:31:04 pm
Thanks Dave
Darby Edelen
Re: Distort effect
on Mar 11, 2010 at 1:23:37 am
This isn't really any easier than using CC Cylinder, but I thought you might be interested to see how it works.
I've included a link to an image that you can use with the Effect > Distort > Displacement Map effect on an Adjustment Layer at the top of your layer stack to create a cylindrical distortion. Try using 100 for the horizontal and vertical displacement.
611_distort.psd.zip
This image may need to be resized for your composition.
Darby Edelen
