problems with the illustrator files
triki yassine
on Mar 6, 2010 at 11:05:46 am
after effects prensents a probleme when handeling an illustrator file, when using the puppet tool an only when slecting the conserve the file poperty option ( to get read of the pixelisation)the base image turns to a mask kind objet and maks the change appears whith transperency... i have find a solution to the probleme is by turning off the conserve property option but i want to conserve the sharpness of the image
Michael Szalapski
Re: problems with the illustrator files
on Mar 8, 2010 at 3:03:26 pm
You could put your Illustrator file in a large composition with the continuously rasterize switch turned on in that comp. Then import that larger comp into your main comp and apply the puppet pins to it.
- The Great Szalam
