Memory & Cache
Nina Bjer
Memory & Cache
on Mar 5, 2010 at 10:29:45 am
I have spend a lot of time trying to get this but still need advice!
In the Memory & Cache preferences one can specify some folders and I would be so greateful if someone can help me with this! :)
Image cache: I enable Disk Cache and choose a folder. Should it be harddrive C or D? Is this Is this the captured files or the preview files?
In Conformed Media Cache there are two folders to choose:
Database: Do I need to specify this? It is set to C/User/Roaming/Adobe/Common.
Cache: Where should I put this? In C as it is or in or D? Is this the captured files or the preview files? Appart from the media cache files.
Thanks in advance!
Nina
Walter Soyka
Re: Memory & Cache
on Mar 5, 2010 at 12:01:14 pm
Have you seen the documentation on these items?
RAM and Disk Caches
The Media Cache
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Nina Bjer
Re: Memory & Cache
on Mar 8, 2010 at 2:06:26 pm
Yes, and I'm still confused.
Nina Bjer
Re: Memory & Cache
on Mar 8, 2010 at 4:08:47 pm
Yes, and I'm still confused, so if there is anyone who knows this and can help that would be very much appreciated! :)
Todd Kopriva
Re: Memory & Cache
on Mar 8, 2010 at 4:25:08 pm
Is there a reason that you think that you need to change this from its default location?
preview files, as described in the "The media cache" page that Walter pointed you to:
"When After Effects imports video and audio in some formats, it processes and caches versions of these items that it can readily access when generating previews. Imported audio files are each conformed to a new .cfa file, and MPEG files are indexed to a new .mpgindex file. The media cache greatly improves performance for previews, because the video and audio items do not need to be reprocessed for each preview."
Is there some reason that you think that you need to change this from the default?
Here is some advice from the "RAM and disk cache" page that Walter pointed you to:
"For the best performance, select a folder that’s on a different physical hard disk than your source footage. If possible, the folder should be on a hard disk that uses a different drive controller than the disk that contains your source footage. The disk cache folder can’t be the root folder of the hard disk."
"If disk caching is enabled, After Effects can store rendered items to your hard disk when the RAM cache is full during standard previews."
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Nina Bjer
Re: Memory & Cache
on Mar 8, 2010 at 8:53:09 pm
Thanks Todd! Okej, so the answer seems to be that I can keep the pre-chosen folders as they are in the Memory & Cache preferences. This is C.
The reason I asked which of these I should put on C or D was that the defolt is C on my computer and I understood that the source footage and the prewiew files should not be on the same hard drive. I have read all the help-sections already and aske here when I don't understand them. And I thought it would be easier to just ask this rather than all the things I don't understand in these texts. It's like learning a new language. :)
Walter Soyka
Re: Memory & Cache
on Mar 8, 2010 at 4:47:56 pm
I'm not really sure what you mean by "capture" or "preview" files -- After Effects doesn't really have either one.
Can you describe a little bit about your setup and what you're trying to accomplish?
Walter Soyka
Nina Bjer
Re: Memory & Cache
on Mar 8, 2010 at 9:02:06 pm
Okej, thanks for trying to help! :) Sorry I'm new to this. I just really thought that one should separate the files of a project into different hard drives for better performance and then I just wanted to know, if I should do this by choosing different hard drives in the Memory & Cache preferences. Here are three folders to be specified (under enable disk cache, database and cache). But from the post above it seems like these can all be as they are by defolt, C. So then I'm just more confused of where to separate the project to different hard drives...
Walter Soyka
Re: Memory & Cache
on Mar 8, 2010 at 9:09:06 pm
[Nina Bjer] "So then I'm just more confused of where to separate the project to different hard drives... "
In my experience, most After Effects users run out of processing power and RAM before hard drive speed becomes an issue. What kind of system do you have?
That said, the general advice (if you don't have a high-speed RAID) is one drive for the operating system and applications, a second drive for footage, and a third drive for renders.
Walter Soyka
Nina Bjer
Re: Memory & Cache
on Mar 9, 2010 at 1:45:27 pm
You're very kind trying to help me! :) Sorry for not getting it!
Yes exactly, its this general rule that makes me think that I should specify the three folders in the Memory & Cache Preferences? Im I really so wrong in this?
1) The first of these folders, with the preview render files, should be on the G-drive, no? If I have already put my captured video files on D?
2) The second folder (Database), I keep on C?
3) And the third folder (Cache), I keep on C?
When you say the application, does that include the project files?
ross tokach
Re: Memory & Cache
on Mar 9, 2010 at 2:08:44 pm
The way I run, I first take my two raid 0 drives and put a partition on them, so I have two 300 GB drives and they are split at 150 x 2, then I raid 0 them together, it will never show you the partitions. It will show as a 600 gig strip. But the Boot segments have been partioned for the sake of the index. Then, I allocate 30 gigs of drive space to paging. Then I add in a 2 gig card on readyboost.
Now I am ready to start allocating save positions for my data. I go into my preferences and set up my cache next to my original source files on the raid 0 in its own folder, make sure the folder name is a higher alpha numeric name such as AA. So you have your footage and your Cache in the same folder, labeled AA.
Then I make a secondary folder with a name such as ZZ, this folder is made directly after I make my cache folder. The ZZ folder is going to be my scratch disk file. it is in this folder you will put all of your save files and renders from anything on the project.
Make sure you use a mirror of some sort to save all your progress, it will help you if you can use an external to mirror to, set up ready boost on it and it helps with your data write speeds to that drive and also helps relieve some of the systems backache.
I hope this isn't too confusing, I hope I could help.
OOP, my render is done!
Walter Soyka
Re: Memory & Cache
on Mar 9, 2010 at 2:23:54 pm
A couple questions for you: Are you running Windows or Mac? How many processors? How much RAM? How many drives do you have attached to your system? What kind of work do you do? What kind of footage files are you working with?
I think that the only reason for moving these folders from their defaults would be to increase performance. When you render, are your CPUs working near maximum load? Is your memory usage maxed out? If either of these is the case, your disks are not a bottleneck and it doesn't matter where you store files. If your RAM and CPU usages are low during render, then redistributing your files and getting faster drives may help.
Personally, Image Cache doesn't do me much good, because I never use standard preview (spacebar). It's not realtime, and it doesn't include audio, so I don't use it. I always use RAM preview (0 on the numeric keypad) or shift-RAM preview (Shift key and 0 on the numeric keypad; it functions the same as regular RAM preview, but you can specify different settings to trade off between speed and quality).
I don't think where the project file is located impacts performance; it's not accessed much except during opens and saves.
I don't have much personal experience with Conformed Media Cache, because I always use intraframe-compressed footage to improve AE's rendering speed and reliability. The only items in my cache are PEK files (audio waveform previews) and a few CAF files (conformed audio files), so I don't think I'd see much benefit from relocating this folder.
Take a peek in your cache folder; if there's a lot of video, you might relocate it to a footage drive, but again, disk speed may not be your rendering bottleneck.
Walter Soyka
Nina Bjer
Re: Memory & Cache
on Mar 9, 2010 at 3:03:45 pm
Thank you ever so much for all you help! :) I had no idea this could possibly be this complicated, but I'll do like you said and hopefully i'll work! Again, thanks so much!
Nina Bjer
Re: Memory & Cache
on Mar 9, 2010 at 3:26:12 pm
I'm on a Windows laptop.
Core(TM)2Duo CP T7500 @2.20GHz
4 GB Ram
I have one external harddrive that I previously only used for backup but now for the render files.
I make films of one to four minutes, with filmed hd footage
Quicktime or Windows Media files, and animate this sometimes, one film had 300 layers, effects etc.
I don't know about the cpu-usage or memory usage, but will try to check this... although ofcorse I don't know how to do that either... oh! :)
Ross Tokach
Re: Memory & Cache
on Mar 12, 2010 at 11:12:33 am
Try using CS4 instead of FCP. Then create your timeline normally, open a sequence that is 1/4 resolution , change your slider to fit, cut the film. Highlight everything and copy it. Open the tab for the originial native HD timeline and paste that sucker in there. Hit enter and go to the fridge. Come back export directly into aftereffects, render, go to walk the cat, come back and start your effects. Export it as full losseless quicktime.
"Oop, I think my render is done!"
Nina Bjer
Re: Memory & Cache
on Mar 12, 2010 at 1:16:09 pm
Thanks very much for the tip! I can't use CS4 on my computer, only CS3, not good enough unfortunately, but when I get a better computer and CS4, i'll remember you tip! :)
