How to add an additional tracker
Bob Stevens
on Mar 4, 2010 at 3:57:00 pm
I am tracking for Position, Rotation, and Scale. When I click those options it gives me two trackers to use.
I'd like to add an additional tracker. How do I do that?
Todd Kopriva
Re: How to add an additional tracker
on Mar 4, 2010 at 11:45:30 pm
The number of tracking points is determined by what kind of tracking you're doing.
from "Track or stabilize motion":
"When you select Rotation or Scale in the Tracker panel, you set two track points in the Layer panel.... After Effects calculates rotation by measuring the change of angle of the line between the attach points.... After Effects calculates scale by comparing the distance between attach points on each frame with the distance between the attach points on the start frame."
Why is it that you want a third point?
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
© 2018 All Rights Reserved
