why does my video become blocky after being rendered?
patrick collins
on Mar 2, 2010 at 6:50:29 pm
I am not sure if I am doing something wrong.. But I have standard DV footage, and from what I can tell, my composition settings in AE are set to standard DV...
When I look at a section of the background of my original footage, it looks normal like this:
http://collinatorstudios.com/www/original.png
but after I render my movie with AE, everything looks blocky and pixelated like this:
http://collinatorstudios.com/www/aftereffects.png
Any suggestions?
-patrick
Anthony Giola
Re: why does my video become blocky after being rendered?
on Mar 2, 2010 at 7:07:59 pm
Under settings in the render q make sure the quality is not set to (use project settings) make sure it is set to best and make sure you are using a correct video format
Steve Roberts
on Mar 2, 2010 at 8:09:44 pm
If your video was shot progressive, make sure that AE didn't separate field on import. Select the footage, then file>interpret footage> main. If the footage is progressive, set "separate fields" to "off".
patrick collins
on Mar 2, 2010 at 10:26:58 pm
ah thank you! separate fields off did the trick.
-patrick
