Making a countdown timer
Chris Lowry
on Feb 24, 2010 at 5:37:44 pm
Hi there.
Trying to make a clock that counts down from 60 seconds to 0. Displaying it exactly like the 60, 59 ,58, etc.
How do I do this. I've played with Effect>Text>Number, but I don't get it.
Anyone wanna give me a clue?
Bless,
Chris
Andy George
Re: Making a countdown timer
on Feb 24, 2010 at 5:51:32 pm
Chris,
Try this-
Apply the number effect to a solid. Set your decimal places to 0.
Set a keyframe on the value offset property. Set it to 60. Move forward in time and
set a keyframe to your value offset property. Set it to 0
-Andy
Chris Lowry
on Feb 24, 2010 at 6:18:26 pm
Excellent, I understand: but how do I create a keyframe? I have the layer selected, and the numbers part of the layer selected, but when i go to Animation>Add keyframe its greyed out.
See the screenshot here: http://www.uploadscreenshot.com/image/50574/7846877
Also, how do I export the finished file so that Premiere can import it? I'm gong to want to place the clock over other stuff, so how do I alpha channel the black bg?
Chris
Andy George
on Feb 24, 2010 at 7:11:01 pm
Hi Chris,
One way to make a keyframe is by clicking on the stopwatch of the property you want to animate.
Then when you adjust the value of the property a keyframe will be created.
If you render to the "lossless with Alpha" preset in your render Q it will create an
alpha channel were there is no image.
I would recommend taking a few moments with some beginner tutorials.
Here are some good ones-
http://www.videocopilot.net/basic/
-Andy
Dave LaRonde
on Feb 24, 2010 at 7:52:20 pm
Have you ever thought about doing a search in the forum using the term, "countdown timer"?
Do you know how many times this has been covered?
Dave LaRonde
Sr. Promotion Producer
Chris Lowry
on Feb 24, 2010 at 11:09:38 pm
Yes I had searched several times, but people tend to assume you know as much as they do and miss crucial steps that seem obvious to them. I know to create a keyframe, what I don\'t know is why its greyed out?
Any idea?
Dmitry Nikitin
on Feb 25, 2010 at 9:49:21 am
You might overlay with this timer.
