quicktime movies always look different
Tanner DeVries
on Feb 18, 2010 at 9:03:16 pm
I seem to be having a problem with my dv footage when I play it back in quicktime the footage seems to look of higher quality and not pixelated than when I play it back in after effects, any idea why? I've actually opened the footage in several programs and the footage seems to look better in quicktime and the same in those other programs as in after effect. I've attached a photo:
Dave LaRonde
Re: quicktime movies always look different
on Feb 18, 2010 at 9:35:27 pm
Are you taking care of the interlacing properly?
Dave LaRonde
Sr. Promotion Producer
Joey Foreman
on Feb 19, 2010 at 1:42:04 am
Sometimes AE incorrectly interprets your footage as interlaced when it's not. In the Footage panel, ctrl-click on your footage item and chose Interpret Footage > Main. In the section called Fields and Pulldown, where its says Separate Fields, see what this is set to. It might say Upper Field First or Lower Field First. If you know your footage is not interlaced, change it to off.
Before you do that, though, be sure in the comp window the resolution is set to Full, and that in the Timeline the layer is at normal, rather than draft quality.
Tanner DeVries
on Feb 19, 2010 at 7:30:45 pm
Yeah just had to switch it to off that worked great, thanks
