Windows Stuck in corner
Brandt Dijksterhuis
on Feb 17, 2010 at 8:44:29 pm
The when i open after effects the windows is fixed in a corner...
The following picture will give a better explanation: http://grab.by/2uqd
Thanks in advance...
Brian Charles
Re: Windows Stuck in corner
on Feb 17, 2010 at 9:16:13 pm
Either press Command + | or go to the Window menu and choose Workspace > Reset "Standard".
Brian Kessler
on Apr 2, 2010 at 8:15:23 pm
I'm having the exact same problem, and neither of those suggestions worked. (Obviously they were the first things I tried.) Did you fix it?
Brian Kessler
on Apr 2, 2010 at 8:29:35 pm
I fixed it. I just changed my monitor resolution to something lower, then switched it back and it was fine. (On a Mac. Not sure if you were on a PC or not.)
