Depth of field issue
Layne Haacke
on Feb 16, 2010 at 6:30:21 pm
Sorry to bring up this problem again, but I never saw a good answer to it.
It is referenced in this previous thread.
http://forums.creativecow.net/thread/2/970581#970680
If I'm missing some simple setting let me know, but when I turn on Depth of Field this very pronounced banding/glitch appears.
It's easy to recreate.
HD Comp
solid layer (make it light gray it shows up a lot more) make 3d
make Camera
turn on depth of field
put camera on an angle
turn the blur level up quite a bit to 950%
It will show up in the lower right corner
(here is the camera info)
Camera Options Zoom
1866.67
Camera Options Focus Distance
2290.41
Camera Options Aperture
17.7165
Camera Options Blur Level
percent 950
Transform Point of Interest
X pixels Y pixels Z pixels
752.412 659.678 -157.189
Transform Position
82.2217 1305.76 -1775.17
Todd Kopriva
Re: Depth of field issue
on Feb 16, 2010 at 7:37:02 pm
Do you just see the banding when you preview in After Effects, or do you see it in output files, too?
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Layne Haacke
on Feb 16, 2010 at 9:33:28 pm
It's on the full resolution renders.
Adrian Ridley
on Feb 23, 2010 at 4:20:19 pm
I'm having the same problem in preview and renders (attached). I have tried outputting at a color depth of 32 bit but I don't have enough memory to create the blur. Please help.
http://i1.creativecow.net/u/44962/final_00047.png
