Rendering, text disappears
Rob Johnson
on Feb 10, 2010 at 4:22:14 pm
Goodday,
I have a introduction clip in AE CS4, when i render this clip though, the text disappears and re-appears again for some reason. In the preview the clip looks "perfect" nothing disappears.
I have uploaded a part to youtube to give you a better look on the issue.
As you can see the text "1nsane Productions" disappears and re-appears after a few frames.
I tried rendering in different codecs, this didnt work. I tried the "OpenGL" rendering, strangely this did work but he quality is just terrible!
I hope someone can help me, I dont like to see my work go to waist.
Dave LaRonde
Re: Rendering, text disappears
on Feb 10, 2010 at 4:57:06 pm
[Rob Johnson] "I hope someone can help me, I dont like to see my work go to waste. "
Well, that's hard to say: insufficient information for an accurate diagnosis and all. How did you go about making this animation? Details are good.
Dave LaRonde
Sr. Promotion Producer
Rob Johnson
on Feb 10, 2010 at 5:34:43 pm
It's a bg with 4 text items on there, camera flies from 1 text to the next.
Update:
I have managed to render it properly now @ 1/3rd of the original resolution. (I "ram previewed" the clip, then I saved the ram preview).
Looks like its size related. Because when I set the ram preview to "Full"( 1280*720), the text dissappears aswell!
My system:
Q6600 @ 3.2 Ghz
4 Gb DDR2 1066 (3.5gb)
Win Xp 32bit
Dave LaRonde
on Feb 10, 2010 at 7:24:04 pm
[Rob Johnson] "It's a bg with 4 text items on there, camera flies from 1 text to the next. "
Lots of details in that description, you bet!
I'll take this shot in the dark: separate the text layer in z-space a little more from the background.
Dave LaRonde
Robert S.  Pugh
on Mar 1, 2011 at 1:08:33 pm
I've just experienced similar issues with AE CS5. Apparently there are bugs with AE CS5?. Anyway I followed the advice from this forum and it worked. Thanks for your help
Kevin Reiner
on Feb 11, 2010 at 1:05:36 am
Dave's suggestion should work. If you have motion blur on and the text is on the same plane as the layer below it, the layering gets weird. Problem that AE has had since they went 2.5D.
If moving it in Z space doesn't work, place an adjustment layer directly below the text layer in the timeline.
System Setup (for a more detailed list, see my profile)
HARDWARE
Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
9GB Memory
Two 16x SuperDrives
Dual-channel 2Gb Fibre Channel PCI Express card
Apple Cinema HD Display (23" flat panel)
ATI Radeon X1900 XT Graphics Card
AJA Kona LHe SD/HD capture card
Apple Xserve Raid 5.6TB
SOFTWARE
Mac OS X 10.4.11
Final Cut Pro Studio 2
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum 5
Sapphire Plug Ins
Roxio Toast
Digital Anarchy Anarchist Suite
ParticleIllusion 3.0
Trapcode
Zaxwerks
Rob Johnson
on Feb 11, 2010 at 12:41:25 pm
Thanks to both of you.
Moving the text in Z space (10 pixels) solved the issue!!
