Non-standard frame encoding
Scott Inukai
on Jan 30, 2010 at 8:30:26 pm
I'm trying to encode/compress a non-standard frame size (1538w x 32h) for a client proof out of AE CS4. I used to be able to do a windows media file but it seems with the new version of encoder I can't change the frame size to something so far from standard.
Any suggestions?
Todd Kopriva
Re: Non-standard frame encoding
on Jan 31, 2010 at 12:15:28 pm
You could create a movie in a different format---such as QuickTime or AVI (Video for Windows)---that doesn't have such constraints on frame dimensions.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Walter Soyka
on Jan 31, 2010 at 12:27:13 pm
Not all codecs allow arbitrary frame sizes; many use blocks of a certain size (for example, 8x8) and require that your video frame be an even multiple of the block size.
You could export a lossless AVI from AE and try one of Microsoft's free encoders; alternately, you might letterbox or pillarbox your output for client review purposes into a standard frame size.
The COW also has a Compression techniques forum, where you might be able to find some help.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
