How to make a clock like this?
Hans Skallevold
on Jan 26, 2010 at 3:16:23 pm
I'm wondering if anyone could help me. How do I make a clock like this one -->
... in After Effects CS4.
I'm doing a sports show at school, and we've done a race so we need that clock :)
Dave LaRonde
Re: How to make a clock like this?
on Jan 26, 2010 at 4:29:28 pm
Use the Numbers Effect over either a shape layer or a solid, with a little Bevel Alpha applied to the lower layer.
If none of what I just wrote made any sense, you need to start here:
http://www.videocopilot.net/basic/
Dave LaRonde
Sr. Promotion Producer
David Franklin
on Jan 26, 2010 at 5:29:40 pm
If it turns out that you DO know what Dave is referring to, then here's a suggestion to go one step further:
You could create a simple expression to fill the value of your number effect with the current time.
Twirl down the "Numbers" effect, then twirl down the "Format" tab. Alt click on the stopwatch next to Value/Offset/Random Max and type the word "time" in the expression field that opens on the right.
Then set the "Decimal Places" value to "2" and away you go!
http://www.artisanaltelevision.com
Made With Care In Brooklyn, NY
