motion tracking problem
Joonas Kuivjõgi
on Jan 6, 2010 at 11:23:57 pm
Hey! I'm pretty new to After Effects, so I'm having some troubles with motion tracking that seem easy to fix but I'm clueless how to do it the "easy" way.
Ok, I did perspective corner pin motion tracking, applied the data to new layer. Everything was perfect until the layer started "rotating" by itself. I tried to solve this by trying almost everything under "Transform" option but no help.
Couple screenshots to show exactly what I mean..
1)this is how ran at start and how it should run - http://tourneycpm.mrlazyinc.com/files/users/emir4nt/Capture_065.jpg
2)this is next frame (wrong way) - http://tourneycpm.mrlazyinc.com/files/users/emir4nt/Capture_066.jpg
this lasts for about 70 frames so moving the layer manually would be pretty time consuming...
Thanks to advance.
(Sorry if this thread already exsists somewhere, I'm in a hurry)
Thomas Horne
Re: motion tracking problem
on Jan 7, 2010 at 6:35:03 am
My thought is that maybe you mixed up which corner pin tracker goes to which corner? It looks like point 2 became point 3, etc.
This should be pretty easy to check just by following each tracker and seeing if it suddenly jumps to the wrong corner along with the rest...
Joonas Kuivjõgi
on Jan 7, 2010 at 7:33:13 am
I ended up switching corner pins by myself and re-tracked motion.
