Clips freeze after 7-10 seconds
Ryan Moyer
on Jan 6, 2010 at 4:15:13 am
It seems like most of the clips I work on, even if they're just text or animation presets already included in AE/Bridge, will freeze after about the 7-10 second mark.
It's not a rendering thing, as that section of the video shows that it is rendered. Also even if I render the video through the render queue the output freezes at the same section.
I'm running windows, q9400 processor, 4gb ram, 8800gt graphics card.
Michael Szalapski
Re: Clips freeze after 7-10 seconds
on Jan 6, 2010 at 4:35:50 am
Do you have multiprocessing turned on in your preferences? If so, turn it off; you don\\\'t have enough RAM for it.
- The Great Szalam
Ryan Moyer
on Jan 6, 2010 at 7:22:07 am
No, it is turned off.
However, my ram usage isn't adding up. It says I have 3.25gb installed, with 0.5gb left for other applications, but has total After Effects memory usage listed at only 1.2gb.
The Render Multiple Frames Simultaneously box is unchecked.
Michael Szalapski
on Jan 6, 2010 at 2:15:35 pm
What version of Windows are you running?
What version of AE are you running?
Do you have the latest updates to AE?
Do you have the latest driver for your graphics card?
Do you have any OpenGL settings on such as rendering with the OpenGL renderer?
- The Great Szalam
Ryan Moyer
on Jan 11, 2010 at 3:46:45 am
Windows XP
CS4 9.0.0.346
Yes
I didn't change any of the original settings in regards to this, but when I go to preferences -> preview the enable opengl checkbox is checked, as are the two checkboxes beneath it.
Dave LaRonde
on Jan 6, 2010 at 3:35:43 pm
[Ryan Moyer] "Also even if I render the video through the render queue the output freezes at the same section. "
This leads me to suspect three things:
1) you rendered a high-quality file from AE, which is good
2) you're looking at this on a simple media viewer
3) the file is playing back on a single hard drive, not something like a RAID
If all that's true, then don't sweat it, the animations are probably fine. You hard drive simply can't keep up with the high bitrate of a high-quality file. To reassure yourself that all is okay, use something like Adobe Media Encoder to convert one of those files to an mp4 or an h.264. Even though you don't want to make such files in AE, they're more highly-compressed, so you should get smooth playback.
Dave LaRonde
Sr. Promotion Producer
Ryan Moyer
on Jan 8, 2010 at 2:04:05 pm
1) yay!
2) It was a simple media player, but when I imported it to Vegas it was doing the same thing.
3) Unfortunately yes, this is on a single drive. I've never had problems with Vegas working off a single drive but I guess that's not true of AE and I'll need to set up Raid or an SSD?
Dave LaRonde
on Jan 8, 2010 at 3:44:45 pm
[Ryan Moyer] "3) Unfortunately yes, this is on a single drive. I've never had problems with Vegas working off a single drive but I guess that's not true of AE and I'll need to set up Raid or an SSD?"
My guess is no. It's a guess because I don't really know the details about Vegas. But if it woks like most NLE's, then it will render the high-quality footage to the codec you use in your edit timeline.
Alternately, you could simply render out of AE in the cidec used in your edit timeline. Either is okay.
Dave LaRonde
Ryan Moyer
on Jan 13, 2010 at 3:42:11 pm
Good info here, but I'm still a bit confused as to what action I need to actually take to fix my problem...
Michael Szalapski
on Jan 13, 2010 at 3:59:03 pm
Are you saying AE freezes at the 7-10 second mark during rendering in the render queue AND when playing back RAM previews?
What elements do you have in your comp?
What happens if you move the work area to render from the ten second point on?
Does this happen in all comps in all projects?
- The Great Szalam
Ryan Moyer
on Jan 14, 2010 at 12:32:38 am
Yes, in the render queue and when playing back via a ram preview, or even a regular preview.
If I move the work area past the freeze point all I get is the frozen part. When I said 7-10 seconds I didn't mean between the 7 and 10 second mark it is frozen and it works fine everywhere else, I meant that at some point (usually around 7, 8, 9, or 10 seconds but not always necessarily within that range) it freezes and remains frozen from that point until the end of the comp.
