Precomps and the playhead
James Ireland
on Jan 4, 2010 at 11:25:23 pm
Firstly sorry if this is a dumb question,
I've a large composition that contains several precomps.
When I move between main composition and precomps the playhead does not 'land' in the same positon. For instance if in the main comp the playhead is a 4:00:00 and I jump to a precomp the playhead is now at 4:00:10. Its only when I select the precomp and right click open compostion that the playhead is positioned correctly. However when I go back to the main comp the playhead has changed position again.
It was working fine and landing correctly until an hour ago and now it's all over the place...
I know this must be so simple a problem but I'm just stuck.
Thanks for help.
Dave LaRonde
Re: Precomps and the playhead
on Jan 4, 2010 at 11:30:20 pm
In Preferences -- the General section, I think -- you may want to change the check box state of the Synchronize Time Of All Related Items setting.
Dave LaRonde
Sr. Promotion Producer
James Ireland
on Jan 4, 2010 at 11:44:55 pm
Hi Dave and thanks.
I switched it off and it made no difference. However I just switched it back on again and now it's all working!
Wood, trees, 11.45 GMT. Calling it a night!
Cheers,
J
