suretarget(AE) and trapcode
martin weterholt
on Dec 23, 2009 at 11:22:47 pm
Hello all,
I've got a problem that i need your help with. I'm going to explain it as clear as i can.
I have made a composition with a camera and about 13 text(3d layers). These layers are followed with suretarget. That's working fine.
Now i want a nice 3d stroke under the 3d text. But when i make a new solid, make a line and then apply the 3d stroke, it doesn't work.
i only see my written line.
I've tried the following:
- use comp camera
- use a preset
- create a new solid
nothing works. How can i apply the 3d stroke to my camera so i can see the created stroke and how do i make it move with my suretarget presets.
Travis Howle
Re: suretarget(AE) and trapcode
on Dec 25, 2009 at 4:34:00 pm
Have you tried to make the solid, and use the 3D Stroke from Trapcode, with a mask, and then change the start/end over time to follow the movement with the camera?
I don't have AE in front of me right now, but that is how I did it to make the effect work a while back.. if I am understanding what you're asking.
Hope it helps!
Merry Christmas
martin weterholt
on Dec 26, 2009 at 11:54:18 am
can you tell me how to do thius exactly, not quite sure if i'm doing it correctly..
martin weterholt
on Jan 4, 2010 at 11:04:45 am
anyone?
