"lock" position of a mask
Stephan Dube
on Apr 4, 2008 at 1:02:47 am
Hello
Im a new user of After FX, I believe my question should be fairly easy...
I woudl like to know how do you "lock" the position of a mask?
What I am trying to do is to move a layer around but keep the mask on the same place. now when I move a layer with a mask the mask follows it.. I want to "lock" the mask position...
Any thoughts?
thanks
cheers
Ben Heusner
Re: "lock" position of a mask
on Apr 4, 2008 at 6:19:09 am
Hi Stephan,
You want to use a track matte.
Create a mask on a solid layer that lies on top of the layer you want to cut out. Then click on the TrkMatte dropdown menu on your footage layer, select Alpha Matte.
Here's the layer order for you:
1) Masked solid
2) Your footage - Track matte set
3) Background (if used)
Now you can move your footage layer around and the mask won't move.
Hope that helps,
Ben
Curious Turtle Professional Video
Training | Editing |Support
http://www.curiousturtle.com
Stephan Dube
on Apr 4, 2008 at 9:36:11 pm
dude thanks so much.. it works like a charm :)
cheers
Stephan
Matthew Gaunt
on Jan 20, 2013 at 10:09:45 pm
I had exactly the same question and it worked perfectly! Thanks so much for your crystal clear answer.
Cheers, Matt
Marianna Rudakova
on Apr 20, 2017 at 11:08:22 am
Thanks a lot!!!
