Is it possible to make effects end on the same position as in the start of the composition?
Mathijs de Nooijer
on Jul 30, 2020 at 6:51:13 pm
I'm trying to create a seamless loop for an animated twitch overlay. If I use the cutting/transparency technique you can still clearly see where I made the cut. So I was wondering if perhaps it's possible to force an effect to "work towards" the same position as where it started at the beginning of the composition.
Not sure what terms I should use to look for the answer here.
Blaise Douros
Re: Is it possible to make effects end on the same position as in the start of the composition?
on Jul 31, 2020 at 12:05:39 am
https://www.google.com/search?client=firefox-b-1-d&q=making+a+seamless+loop...
In particular, I like this one:
Just precompose your effect, duplicate it, and use it like footage. Works every time.
