Time remapping clip and tracking null
Nicolas Guionnet
on Jul 26, 2020 at 10:56:01 pm
I have a clip.
In it, an object A is tracked.
The tracking target is a null, thus following A.
I need to remap the time of the ensemble ... without having to re-track every time ...
1°) I tried to remap both the clip and the null, controlling the remapping with a slider control. No way. A null cannot be remapped, apparently.
2°) I tried to precompose the clip + the null.
When I try to remap the composition, the null ignores the remapping ... and it stops following A.
How can I do this ?
Is there a way to convert the tracking null to a normal moving object ?
Chaz Chester
Re: Time remapping clip and tracking null
on Jul 26, 2020 at 11:02:12 pm
You should be able to just pre-compose the footage (without any time remapping) and the null together and then time remap the pre-comp itself, right?
Nicolas Guionnet
on Jul 26, 2020 at 11:10:00 pm
OOOPPPs ! Wrong diagnostic !
You're right Chaz ... and in fact, it works ! ( Thanks for your answer ! )
BUT ... I have another problem as an expression outside of the precomposed [ clip + tracking null ] tries to access the position of the null ...
It seems that it only gets the position at the present time ( without the time remapping ).
Is there a way to solve this ?
Thus, this post is now expression oriented ... (sorry, wrong forum )
Nicolas Guionnet
on Jul 26, 2020 at 11:25:15 pm
I simply used this code to solve my problem :
yourTime=thisComp.layer("tracked-ball").timeRemap;
pos = comp("tracked-ball").layer("motion-tracker").transform.position.valueAtTime(yourTime);
Chaz Chester
on Jul 26, 2020 at 11:36:47 pm
....or that. Glad you got it figured out 👍
Chaz Chester
on Jul 26, 2020 at 11:35:54 pm
One solution would be to pre-compose the layer that has the expression on it and apply the same time re-mapping to that pre-comp. If the position data is staying the same (like, you're not planning on re-tracking the shot or moving the null), you could could convert the expression to keyframes and then re-time the keyframes to sync up with your time remapping. You can easily scale the timing of several keyframes by selecting them and holding down option/alt while dragging the first or last selected keyframe from side to side.
