Importing Comps from other Projects
Mark Whitney
on Jul 1, 2020 at 1:16:40 am
Probably a very basic question, but I've been away from AE for some time now & can't find my oil can.
I'm using CS6 & revisiting some projects from 2013-1205. A number of older plug-in complaints of course but finally got those resolved. For the comp I need, I've a complicated section where the mattes aren't working for some reason. In an earlier version of the comp, but in a different project, they are. Having a time really seeing what's different when having to Open & Close, back & forth, so would like to just bring that comp into current project so I can more easily compare what's different or simply swap out.
I vaguely recall a technique for doing that but not finding it. Might be confusing bringing AE projects into Premiere.
Anyone?
Thanks.
Walter Soyka
Re: Importing Comps from other Projects
on Jul 1, 2020 at 10:29:50 am
You can use File > Import to pull one AEP into another -- all comps and all assets. You might want to reduce the project you plan to import first.
Walter Soyka
Mark Whitney
on Jul 1, 2020 at 4:11:01 pm
Ah. Knew it had to be a simple process. I recall the need to prune first.
Thanks Walter
