Posterize time with slider control?
Adam Lewen
on Jun 21, 2020 at 7:48:30 am
Hello all!
I have a piece of footage I would like to make as a webcam/intercom.
Effect-wise I am good.
But I would like to have portions of it glitchy.
Posterize time will be great here, but I would like a slider of some sort to be connected to it, to control areas where the glitches will be more/less or none...
While writing this post I understand more, but I am weak with expressions.
Anyone here knows how to direct me?
Thank you so much!
Filip Vandueren
Re: Posterize time with slider control?
on Jun 21, 2020 at 11:12:22 am
What do you want to keyframe ? The exact moments at which the framerate drops ? (then you might as well keyframe the framerate directly).
Or more like a probability that it might glitch ?
What kind of glitch do you want: a simple freeze, or something more jittery like the frames are out of order ?
Adam Lewen
on Jun 25, 2020 at 12:22:51 pm
Eventually a friend put on a little data glitch plugin that did the trick.
Thanks for the reply!
