Zooming in makes vector path pixelated
Abd el Ghafour Mohie
on Jun 15, 2020 at 7:09:36 am
When I copy/paste an object from Illustrator or even import it as an Illustrator file and then turn it into vector shapes then I zoom in on it it gets very pixelated, while in Illustrator it maintain its sharpness no matter what.
After Effects 100% Zoom:
After Effects 800% Zoom:
Illustrator 800% Zoom:
Tero Ahlfors
Re: Zooming in makes vector path pixelated
on Jun 15, 2020 at 8:26:05 am
Zooming the viewer only scales up the view of the comp. So, for example, at 1920x1080 that 800x zoom is not pixel per pixel crisp. Also no one is viewing stuff at 800x zoom.
Richard Garabedain
on Jun 15, 2020 at 3:00:01 pm
your mouse wheel does not zoom the camera...it only blows up the screen..
on Jun 16, 2020 at 3:51:37 am
Thanks for your reply.
But, why can't After Effects have the same behaviour as Illustrato as seen in the image above?
Tero Ahlfors
on Jun 16, 2020 at 6:38:40 am
Because you're not zooming the vector information. You're zooming into the rasterized comp view.
Eric Santiago
on Jun 16, 2020 at 12:04:08 pm
Illustrator is a vector design app.
The app will refresh the lines smoothly at all times (well as best it can).
