Frozen frames of Footage Error
Mauricio Munoz
on Jun 13, 2020 at 3:20:58 am
Hello. So, some frames of the footage I'm trying to work with are frozen when I import them into AE. I thought it was a preview problem but I rendered it and the output video still has some frozen frames. I need to do it in AE because I'm using time remapping and 3d cameras. Thank you so much!
14180_zmercyidestiny220200612014419.mp4.zip
14182_grabaciondepantalla20200611alas22.30.27.mov.zip
Graham Quince
Re: Frozen frames of Footage Error
on Jun 13, 2020 at 12:42:38 pm
Really difficult to tell from the clips, but i see what you mean.
I did notice that the original footage is 32fps and your capture is 60fps.
You're using time remapping, but what are the 3D cameras doing?
http://www.YouTube.com/ShiveringCactus - After Effects Tutorials
Richard Garabedain
on Jun 18, 2020 at 6:35:45 pm
it could be that frame rate difference...But i have also had this problem before...When you create a new camera and you move its origin, this tends to happen. for some reason the cameras origin must start at 00:00:00..and once moved its very hard to tell where the try origin really is
