Can I set an animation as a template and assign it to different vectors?
Dan George
on Jun 10, 2020 at 7:29:08 am
Hi all. I have a number of vector people I would like to animate to make them walk, probably about 10 or so. Do I have to animate each one individually or can I animate one of them and then set this as a template and then assigned that animation to the others? I'm concerned that if I spend time animating them all individually and then I want to tweak the way they walk, I would have to tweak each individual animation. Any ideas?
Eric Santiago
Re: Can I set an animation as a template and assign it to different vectors?
on Jun 10, 2020 at 12:53:27 pm
It would be the other way around (from my experience) where you would leave all layers in one comp and toggle on/off for each character.
Now I am not sure how that would work in After Effects using different shapes and sizes.
I spent a great deal in Maya using the Trax Editor but 3D IK is a bit more forgiving than 2D Animation IK.
Eric Santiago
on Jun 10, 2020 at 12:56:09 pm
Sorry, what I meant was leave all appendages in one preComp.
Example, left leg, right leg, etc...
But again, the sizing and shape might be an issue.
