Import Illustrator file (with gradients) to AE. --> PROBLEM --> white gradients in AE
Maciej Dabkowski
on Jun 9, 2020 at 10:56:13 am
Hi everyone.
I have some problem in exporting process AI file to AE.
In Illustrator file I have a lot of layers with gradients.
When I importing this file into Affter Effect, the composition are completely broken. I mean, this all gradients from AI layers are white (without transparency). So It looks like a one big mess and I can't animate it in AE.
You will see it on the attached pictures.
Any ideas? ☹
Here are this pictures:
https://drive.google.com/drive/folders/1E6hy9cJl2DwZYO7YmudDhgweIUrbH7T4?us...
File from Illustrator and the results in AE after importing this file as a composition.
Richard Garabedain
Re: Import Illustrator file (with gradients) to AE. --> PROBLEM --> white gradients in AE
on Jun 9, 2020 at 8:27:41 pm
i would google how to prepare illustrator file for after effects
Ranveer Singh
on Jun 12, 2020 at 9:10:37 am
Looks Like you are using some sort of blending modes on the object in Ai which is not being converted in AE.
can you share the file so that I can check the exact problem?
