Palette Mapper for Adobe After Effects v1.0 officially released - 100% FREE.
Richard Rosenman
on Jun 2, 2020 at 4:50:29 pm
Hi gang;
I've just published my free plugin for Adobe After Effects, called Palette Mapper. It is 100% free! Here's some info about it:
I'm pleased to announce the immediate availability of Palette Mapper for Adobe After Effects.
Palette Mapper is an exciting plugin for Adobe After Effects that extracts the color palette from a video sequence on a frame-by-frame basis and maps it horizontally into an image using vertical lines. Palette Mapper can be used as a creative application to produce beautiful imagery, or as an analytical tool for the study of color grading in film, video and animation.
Mad Max: Fury Road (2015)
Palette Mapper works by scanning each frame of the footage, analyzing all the pixel values to extrapolate an averaged frame color, and mapping them into a set of sequential vertical lines. The result is an image showcasing the changes in tone and luminance throughout the entire length of a sequence. Although there are various tools available to achieve a similar effect, it’s always been through a complex and time consuming process, often hindered by technical limitations.
Monsters, Inc. (2001)
From creative backgrounds to film analysis, Palette Mapper is a must-have plugin for artists, videographers and designers alike. For more info, check out the Palette Mapper Product Page!
Have Fun,
-Richard
Richard Garabedain
Re: Palette Mapper for Adobe After Effects v1.0 officially released - 100% FREE.
on Jun 3, 2020 at 10:02:15 pm
Ive seen this idea done with the average temerature of the day for a year...but its for video...
Eric Santiago
on Jun 4, 2020 at 1:39:42 am
Maybe off-topic but what's the name of that effect that does the directional color smear?
That was up there with lens flare as far as overused effects :)
Richard Garabedain
on Jun 4, 2020 at 3:39:56 pm
i believe the technique your talking about invovles adding a mosaic and then stretching
Eric Santiago
on Jun 4, 2020 at 6:06:40 pm
[Richard Garabedain] "i believe the technique your talking about invovles adding a mosaic and then stretching"
I am not sure if that is it.
I know that it smears the one pixel dependent on a direction to infinity.
I can mimic this by duplicating the layer and masking a thin portion and scale to an extreme amount.
You have to place the anchor in the right spot to achieve it though.
There as a plug-in and now its defunct many moons ago.
Basically stopped working on newer versions of CC.
Richard Rosenman
on Jun 4, 2020 at 3:45:20 pm
That sounds pretty cool. I'd love to check it out - got a link?
-Rich
