Animation in different Framerates
Daniel Firsching
on May 27, 2020 at 4:54:20 pm
Hello, I´m sorry maybe it's an absolut beginner question.
I have an Animation and I have to render it with different frame rate sFrom after effects. What is the best way to do it?
If I'm changing it on the Composition Settings the keyframes are kind off the track/grid. Is there a better solution to this problem?
Thanks.
Richard Garabedain
Re: Animation in different Framerates
on May 27, 2020 at 10:37:56 pm
yea...precomp everything first..then change the frame rate of the most outside comp
Daniel Firsching
on May 28, 2020 at 7:27:28 am
Thanks! Sounds like a good solution.
