Need an expression to automatically position a Light between two tracked Lights.
Tracy Smith
on May 23, 2020 at 11:49:48 am
Hello everyone,
I'm not a master of expressions but I'm trying to learn.
I have a project where I have footage of long fluorescent bulbs moving.
I need to place After Effects Lights all along the length of the bulbs as they move.
I'd like to have 5 lights per bulb.
I have tracked the ends of the bulbs and positioned lights there. I now need to place 3 lights between the two tracked lights. I believe an expression could be written to position a light between the two tracked lights but I'm not sure how to proceed. Ideally I'd like 3 lights between the two tracked lights for a total of 5 lights per bulb. So the expression would need a variable to position a light somewhere along the line between the two tracked ends. If anyone has an idea I would love to hear it. Thank you so much After Effects gurus!
Jason McKee
Re: Need an expression to automatically position a Light between two tracked Lights.
on May 24, 2020 at 3:34:18 pm
This might help you out.
https://aescripts.com/malcolm-in-the-center/
If that one doesn't work for you then you might be able to get something close with this one. I hope this helps.
https://aescripts.com/align-3d/
Walter Soyka
on May 26, 2020 at 3:16:29 pm
Here's a project that demonstrates the scenario you describe:
[image]
14144_stringoflights.aep.zip
[project file]
In this setup, I've added three Effects Controls to each follower layer:
1) A Layer Control (renamed to "Beginning"), where I select the line's beginning point
2) A second Layer Control (renamed to "End"), where I select the line's ending point
3) A slider control (renamed to "Completion"), where I can animate along the line from the beginning to the end
Each follower layer also has this expression on its Position property. I've commented it here to explain what it's doing. If you have questions, I'd be happy to try to answer them.
// get our effect controls into some variables we can easily use
var lA = effect("Beginning")("Layer");
var lB = effect("End")("Layer");
// make sure that the completion value scales from 0 to 1
var completion = linear(effect("Completion")("Slider"), 0, 100, 0, 1);
// get the positions of the Beginning and End points in world space
var pA = lA.toWorld(lA.anchorPoint);
var pB = lB.toWorld(lB.anchorPoint);
// start the beginning, then add a percentage of the vector from the beginning to the end
pA + (pB - pA) * completion;
Walter Soyka
