mochila tracking is not going well
Jesper Pedersen
on May 21, 2020 at 10:04:49 am
Hi everyone, I´ve spent more than 10 hours on this issue, I´ve seen lots of videos, I have read dozens of posts, I´m a Mocha newbie but that being said, I find the following problem very peculiar - I enclose 5 pictures as documentation,
1 The tracking in Mocha is perfect(trans, scale, rotate) I turn it off and return to the AE interface and press Create Track data and choose "Layer 1"
2 I import the video "Fairy dust" which is suppose to follow the path of the main movie and mask out the part of the movie that isnt relevant I the part of the "Fairy dust" movie that is relevant.
3 Here I have repositioned the "Fairy dust" mask above the princess.
4 In the Mocha effects panel I choose the "transform" option and then layer expor to "Fairy dust" the 5 dots appear on the face of the princess - and follows the movement of her face, so everything seems perfect so far!
5 But when i press "Apply export" - the masked Fairy dust object moves away from its position, and I cannot in any way get it back! In this case, it fairy dust masked movie is seen to the left of the princess-
Question: How to fix this?? thank you very much in advance...
Graham Quince
Re: mochila tracking is not going well
on May 23, 2020 at 9:25:35 am
Is the fairy dust layer the same dimensions as the comp? You might need to precomp the fairy dust layer.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
