Texture Mapping Using Element 3D
Daniel Provenza
on May 16, 2020 at 10:03:18 pm
Hey Everyone. I'm new to Element 3D and having an issue with this 3D Model I purchased. I can't seem to Load the texture map provided properly. Here are the Assets.
https://www.dropbox.com/sh/ezq3u837j1w73f3/AAC6ulPxaPJBhHB9p-ziU4p-a?dl=0
Graham Quince
Re: Texture Mapping Using Element 3D
on May 17, 2020 at 5:03:14 pm
Does that model import? It looks like a .max file and element Can only take OBJ and C4D files. Have you converted it in C4D Lite and did it import correctly into that program? It might be the texture mapping from Max doesn’t conform to something element can read so if you can get the model working in C4D Lite with the texture intact and in the right place you should then be able to export it and then import into element.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
