Nonlinear movement
Yushi Ouchida
Nonlinear movement
on May 12, 2020 at 8:58:35 am
Hello,
I'm begginer on After Effects and not flluence to English.
I want to know how to make not straight move like this
https://dribbble.com/shots/3873122-Shapes?utm_source=Clipboard_Shot&utm_cam...
I inferred to create path and copy it to position, but I don't think that's the best way.
Is there any way to make curvey shape movement?
Thank you
Richard Garabedain
Re: Nonlinear movement
on May 12, 2020 at 6:40:45 pm
first change the anchor point to the top of the box and then try animating it. but the term you most probably want is typograpghy tutorial
Greg Gesch
on May 12, 2020 at 11:50:04 pm
Hi Yushi. As Richard suggest "typography" (he made a mistake in spelling it) would give you a lot of information on how to do things like that. It deals with text but shapes can use similar techniques.
Yushi Ouchida
on May 13, 2020 at 8:24:04 am
Hi Richard and Greg, thanks for the reply.
I never thought about change anchor point.
And I'll check out typography tutorial!
