Creating a script to split a footage into multiple comps?
Alexis Coco
on Apr 27, 2020 at 4:20:02 pm
Hi there,
I'm working on a script that allows me to cut a long footage into several compositions.
The idea is that on a 5 minutes footage for example, I get 30 seconds comps with a 10 seconds delay on my footage between each comps. Finally, I'll have 27 comps of 30 seconds with my footage in them, which starts 10 seconds later each time.
Unfortunately, I can't figure out how to create a function that allows me to cut my items at a given interval and then loop it.
Do you have any ideas?
Thank you very much!
Walter Soyka
Re: Creating a script to split a footage into multiple comps?
on Apr 27, 2020 at 10:53:11 pm
Voila!
I'm here to teach, so please ask questions for anything you don't understand.
// we might make a lot of comps, so let's make sure we can un-make them easily!
app.beginUndoGroup("Make some comps!");
// set originalSource to refer to the footage item you want to offset across your comps
var originalSource = app.project.item(1);
// how many seconds should each comp be?
var compDuration = 30;
// how much time should we offset in each new comp we create?
var timeOffset = 10;
// keep creating comps until we've offset the entire duration
for (var i = 0; i < originalSource.duration / timeOffset; i++) {
// make the new comp with the same properties as the originalSource, but at our custom duration
var newComp = app.project.items.addComp("Comp " + (i+1), originalSource.width, originalSource.height, originalSource.pixelAspect, compDuration, originalSource.frameRate);
// add the originalSource as a new layer in that new comp
var newLayer = newComp.layers.add(originalSource);
// pull the start time back according to the total offset for this specific comp, then trim the inPoint back to zero for cleanliness's sake
newLayer.startTime = -timeOffset* i;
newLayer.inPoint = 0;
// delete the comp if the duration of the trimmed footage is less than the duration -- no blank spaces!
if (newLayer.outPoint < newComp.duration) newComp.remove();
app.endUndoGroup();
Walter Soyka
Alexis Coco
on Apr 28, 2020 at 8:33:51 am
Hi Walter,
Thanks a lot for your amazingly fast answer 😃
That's exactly what i was looking for.
I was stuck with this:
And that one is the cherry on the cake:
Thanks a lot for the help, your code is very clear 😉
So helpful!
Alexis
