Smooth Warping Along a Cylinder
Jennifer Adams
on Apr 19, 2020 at 12:47:16 pm
Does anyone have a guess how they pulled this cylinder-warping effect off? (it's at 00:40)
https://vimeo.com/285440906
This doesn't seem like a very complicated effect, but I'm having trouble pulling it off right. CC Cylinder on a precomp is not doing a good job, because everything inside gets extremely stretched and warped:
I've been fighting with this all day, counter-warping the layers inside the precomp, flipping them horizontally so they're not inverted when we're looking at the cylinder's inside... Ugh, it just feels like I'm going down the wrong path.
Any ideas?
Jennifer Adams
Re: Smooth Warping Along a Cylinder
on Apr 19, 2020 at 1:09:49 pm
Got it, just make the precomp much larger.
Richard Garabedain
on Apr 20, 2020 at 9:52:28 pm
why are you using cc cylinder for such a thing..you need actual layers to fly around a null..not faked with cc cylinder.
Jennifer Adams
on Apr 21, 2020 at 7:09:57 am
Take note of how the elements (particularly the lines) warp around the characters as they travel around them. You can't do that with straight-up layers, since they can't bend in 3D space.
Richard Garabedain
on Apr 21, 2020 at 2:52:32 pm
but they can...animate the layers then go to comp settings advanced 3d then add a curvature to all your layers by going to the material -light -etc-options properties of the layer
