3D null object
Julia Dunkins
3D null object
on Apr 19, 2020 at 8:56:38 am
Hi there,
I have created a slideshow and linked the images to 3D objects. I have use the null object to move the images around. However for some reason some of the images glitch since the points between the path are uneven. Is there any way I can delete some of these points?
The path goes from one image to another. I an delete the anchor points from the beginning to the end for each image but not the little red dots in between and these are the ones who mess up the movement.
Thank you.
Graham Quince
Re: 3D null object
on Apr 20, 2020 at 7:40:49 pm
Check out the smoother (it’s a window, not an effect) that will smooth out your path.
https://helpx.adobe.com/uk/after-effects/using/assorted-animation-tools.htm...
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
