Closing unlocked project panel resizes side panels rather than main locked project panel?
Andrew Marston
on Apr 8, 2020 at 12:54:08 pm
Every time I close a second project panel, it resizes the size panels rather than the main locked project panel where I'm viewing the main comp. This causes me to have to drag and resize the size panels. Does anyone know how to force the side panels to stay the same size and the main comp project panel to expand and fit the space? Thanks much!
Graham Quince
Re: Closing unlocked project panel resizes side panels rather than main locked project panel?
on Apr 10, 2020 at 2:53:24 pm
Not a clue, but I'll bet it's using the same principal as HTML tables when you have columns with set widths - the last column's setting are ignored. You've got a locked panel, so that's not going to change as you've got an unlocked panel which is flexible.
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
http://shiveringcactus.wordpress.com/ - FX blog
